石榴姐
[Lichuang Classroom] Temperature and humidity alarm based on 51 microcontroller
1. Function description:
  • This design is a temperature and humidity alarm system based on STC89C51/52 microcontroller;
  • It is equipped with four independent buttons, whose functions are set, add, subtract and confirm respectively, which can realize the adjustment of alarm threshold;
  • This design uses AT24C02 memory chip, which can still save the set alarm threshold in the event of power outage;
  • This design uses LCD1602 liquid crystal display. The upper row displays the current temperature and humidity, and the lower row displays the corresponding cold, hot, dry, and wet conditions;
  • The fully digital temperature and humidity sensor DHT11 is selected, which has a wide temperature measurement range and can meet general needs;
  • When the temperature or humidity exceeds the threshold range, there will be a buzzer alarm prompt and the corresponding LED alarm light will light up;
2. Design features:
  • PCB board size is 8.2cm×10cm, and can be sampled at Jialichuang;
  • Except for the power supply socket, all other components use direct plug-in devices to facilitate welding;
  • Powered by microUSB.
3. Accessories
  • The program in the attachment, C file and Hex file, is not well written (very bad kind of bad, can only be said to be usable);
  • The program is for reference only, everyone is welcome to optimize it.
4. Video demonstration:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 04:34:18
