蓝猫淘气
Xianneng small TV 2nd generation
A small TV for you to do when you have nothing to do, addedBeliefRGB (WS2812), with two touch switches added (for forced page change and compatible with DSTIKE Boards, namely 8266_deauther). I don’t like esp01, there are too few interfaces, use esp12 or homemade Xianneng Jingxuan, this generation is compatible with both (the next generation is only compatible with Jingxuan), because esp12 is too big QAQ, Jingxuan is a pin package, you can put a lot below it components,3D packaging (fog). 12864 uses self-made packaging, one is to reduce the volume, and the other is to reduce the thickness.Third, they are poor and cannot afford finished products.. In addition, the touch switch is not very easy to use, and the next generation has been replaced by a dial switch (the kind used in radios). I’m planning to scrap it, but I feel it’s a pity. I hope it might be useful to you.          PS. The program is not fully functional. Use the code PPS shared by Tai Chi Maker         . It has a built-in lithium battery charging and discharging boost and voltage module and power monitoring (undeveloped). Thanks to Tai Chi Maker. Wait for the boss!Jingyi2.jpg
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 18:27:54
  • SAMR21 LEDs and Buttons
  • stm32 transceiver
  • EEworld 2013 Week 14 (April 1-7) Highlights
  • WAV playback issues
  • Is LabVIEW a general-purpose programming language?
  • Moderator report: IPTV and digital video discussion area
