qoistoochee128
1.3" OLED FPC interface adapter board
Not long ago, I bought some 1.3" OLED bare screens from a certain fish store. Since they are FPC 16Pin pins. They only support the SPI seven-pin interface, so I haven't used them yet. Because they are bare screens, I need to make an adapter board. I originally planned to find them at Lichuang Kaiyuan. A ready-made one. But all I found were 30pin ones and no FPC16pin ones. So I drew one myself. Note: 15-pin VCC cannot be connected to the power supply when using internal boost. You need to connect 15-pin directly to the capacitor to ground. When using an external Pin 15 needs to be connected to a 9V power supply, so the minimum withstand voltage of the three capacitors C6, C7, and C8 is 16V. I recommend using a 3.3V microcontroller to drive it. If a 5V microcontroller is used, it is recommended to build a level conversion circuit on the signal line, otherwise May affect lifespan.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 18:30:29
