GA5G9
555 running water lamp
Circuit principle: After power on, NE555 and peripheral circuits form a multivibrator. The oscillation frequency is mainly determined by R1, RP and C2. Adjusting RP can change the oscillation frequency. The oscillation signal of the oscillator is output from pin 3 of NE555 and sent to CD4017. At the counting input terminal (pin 14), every time a pulse arrives, the high level of the Q0-9 output of the counter moves one bit in sequence, lighting up the corresponding light-emitting diode, thereby creating the feeling of running water. L11 is connected to the 4017 counting output terminal CO. When L1-5 lights up, the CO terminal of 4017 outputs a high level and lights up L11. When L6-10 lights up, the CO terminal outputs a low level and L11 does not light up. If you think L11 is unsightly, you don’t need to install it, and it won’t affect the circuit operation at all.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 11:11:36
