张三叔
TPS61088 boost module
DC-DC chip TPS61088RHLR input voltage is 2.7-9v, no reverse connection protection, please pay attention to the input polarity. Lead out the EN interface, floating = boost operation, grounding = shutdown. Lead out 2 voltage short-circuit points. After selecting the corresponding short-circuit point to connect, the module will output the corresponding voltage. (Only one of the points can be short-circuited. It cannot be short-circuited at the same time) In the boost module, the input is always lower than the output. Notice. The total output power is controlled within 25W. The TPS61088 is a high power density, fully integrated boost converter with an 11mΩ power switch and a 13mΩ rectifier switch, providing an efficient small form factor solution for portable systems. A wide input voltage range of 2.7V to 12V supports applications using single or two-cell lithium batteries. It has 10A switching current capability and can provide output voltages up to 12.6V.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 18:59:57
