桂花蒸
LM5122MHX synchronous rectifier boost module
DC-DC chip LM5122MHX
Module input 9-20V. Input current limit 15A.
The output voltage is fixed 24V. (Or the potentiometer can be adjusted to 12-24v)
The output current does not exceed 4.5A. The maximum total power is not recommended to exceed 100W.
Appropriately increase the heat dissipation device.
For a boost module, the input is always lower than the output.
The port is two binding posts
The LM5122 is a synchronous boost controller with polyphase capability for high-efficiency synchronous boost regulator applications. The control method is based on peak current mode control. Current mode control provides inherent line feedforward, cycle-by-cycle current limiting, and easy loop compensation.
The switching frequency is programmable up to 1MHz. Higher efficiency is achieved through two robust N-channel MOSFET gate drivers with adaptive dead-time control. A user-selectable diode emulation mode also supports discontinuous mode operation, improving efficiency under light load conditions.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 13:28:35
