黄土马家
SW6124-Two-way fast charging mobile power solution
Chip Solution Battery Power Management Chip SW6124
Support 4.2/4.3/4.35/4.4V battery type (resistance determined)
Support battery temperature protection (NTC optional)
This solution supports Type-A+Type-C+Micro-B three ports.
1 TYPEA output, supports QC3.0/QC2.0/FCP/PE2.0/PE1.1/SFCP fast charge output;
1 TYPEC bidirectional input and output, supports PD3.0/PD2.0/QC3.0/QC2.0/FCP/PE2.0/PE1.1/SFCP fast charge output, supports PD3.0/PD2.0 fast charge input ;
1 TYPEB charging input, (no identification chip configured. Only supports 5V input.)
1 touch button ON/OFF. Battery display, LED light function.
Reserve an LED lighting position
The battery is directly welded. Large-area PCB windows are tinned to reduce internal resistance.
Multi-protocol two-way fast charging mobile power solution supporting PD
SW6124 is a highly integrated two-way fast charging all-in-one chip for mobile power supply. It integrates 4A high-efficiency switching charging.
18W high-efficiency synchronous boost output, multiple fast charging protocols such as PD/QC/FCP/PE/SFCP, power metering, lighting driver and corresponding
Control management logic. Only a small number of peripheral components are needed to form a complete high-performance two-way fast charging mobile power solution.
Button function: short press to turn on the power to display the battery level, double press to turn off the boost output, and long press to turn on and off the backlight.
Note: When connecting the battery for the first time, it needs to be charged and activated.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 13:37:33
