JFET
TPS61088 boost module
DC-DC chip TPS61088RHLR
Description of this module:
Input voltage is 2.7-9v, no reverse connection protection, please pay attention to the input polarity.
Lead out the EN interface, floating = boost operation, grounding = shutdown.
Lead out 2 voltage short-circuit points. After selecting the corresponding short-circuit point to connect, the module will output the corresponding voltage. (Only one point can be short-circuited. It cannot be short-circuited at the same time)
For a boost module, the input is always lower than the output. Notice. The total output power is controlled within 25W.
The TPS61088 is a high power density, fully integrated boost converter with an 11mΩ power switch and a 13mΩ rectifier switch, providing an efficient small form factor solution for portable systems.
The TPS61088 has a wide input voltage range of 2.7V to 12V, supporting applications using single or two-cell lithium batteries. The device has 10A switching current capability and can deliver output voltages up to 12.6V.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-12 09:09:25
