手可摘棉花
Tracer: ESP32-based wearable sports tracker
Have you ever thought about attaching an inertial measurement unit (IMU) to an object to track its posture and motion? Tracer provides high-performance, safe, reliable and low-cost object tracking. Tracer can be easily attached to objects using Velcro. It can tilt and track rhythm as the bike's frame tilts, it can record the number of shots taken with a tennis racquet, and it can even differentiate between topspin and chip shots. Let your imagination run wild and explore more interesting applications of Tracer!
Tracer is based on existing open source projects, can be integrated with Phyphox, and supports users to program using Micropython and Arduino. Users can also use the Espressif ESP-IDF tool to customize it to the greatest extent.
Tracer is an open source embedded project created based on ESP32. Tracer uses a variety of ESP32 software libraries to give developers insight into the necessary processing and algorithms required to develop motion trackers. Tracer has a powerful IMU and ToF that can be used to sense the surrounding environment, and it also supports Wi-Fi and Bluetooth LE connections.
Key Features
- Real-time object tracking using LSM6DSL
- VL53L0X ToF sensor for gesture control and ranging
- The unit can be attached to various objects using Velcro straps
- Onboard Li-ion battery recharges using TP4065
- Battery life: Supports 3 hours of continuous transmission at 10 Hz via Bluetooth LE
- Bluetooth LE transmission distance 15 m (no obstruction, tennis court test)
参考设计图片
Blockdiagram
Design Files
Search Datasheet?
Forum More
Update:2025-07-01 19:04:11
  • Ti DSP optimization basic strategy
  • Everyone cried for 8.5 yuan!
  • May I ask the moderator and everyone, how to solve the following problem?
  • How to burn the program to TM4C123G?
  • About Skyeye fault-tolerant processing mode design
  • Hiring embedded software engineer
