qoistoochee128
STC89C52RC patch to direct plug
Crystal oscillator: Use 12MHz or 11.0592MHz chip crystal oscillator. The jumper cap closer to the crystal oscillator is used to select whether to use the crystal oscillator. A solid circle indicates selection, and an empty circle indicates not selection.
Pull-up resistor: Same as crystal oscillator. The jumper cap close to the top resistor is used to select whether to use a pull-up resistor. A solid circle indicates selection, and an empty circle indicates not selection.
This machine is suitable for PCB hole boards and 51 microcontroller development board chip self-locking seats. There is an additional set of welding ports on both sides of the I/O port, and pin headers or socket headers can be welded as needed to improve the practicality of the machine.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:01:14
