MartinFowler
Cube-415_USB display
Cube-415_USB-Display
·USB display based on ESP32S2
Q group 565264047 Welcome to play~
·Resolution: 320 x 240 / 640 x 480 (PCB uses 2.8-inch 320 x 240)
·Refresh rate: 60fps (theoretical) ~ 18fps (actual jpeg decoding speed)
·Power consumption: 0.70W (MAX) 0.36W (firmware default brightness)
·Driver: Win10 20h2, Win11 2200 tested and available
Power-on effect
connection effect
1080P zoom display effect
Currently, only the firmware of st7789 is provided. The 2.8-inch version is priced at 19 yuan on Taobao with free shipping, and the 2.4-inch version is priced at 17 yuan with free shipping. There is a chance of receiving a sign-in red envelope.
Due to driver reasons, it is currently only available under Windows.
For Linux drivers, please refer to rpusbdisp: https://github.com/robopeak/rpusbdisp
But because the performance is not good, it may be annoying.
Please refer to the original project for driver installation.
Program burning: Manual USB download/ Cube-esp-tool fast burning interface
Burning command:
esptool.py -p (PORT) -b 916200 --before default_reset --after hard_reset --chip esp32s2  write_flash --flash_mode dio --flash_size detect --flash_freq 80m 0x1000 build/bootloader/bootloader.bin 0x8000 build/partition_table/partition-table.bin 0x10000 build/ili9340.bin
(PORT)   Depends on operating system and burning method, for example:
/ Manual USB burning Cube-esp-tool fast burning
Linux /dev/ttyACM[X] /dev/ttyUSB[X]
Windows COM[X] COM[X]
USB needs to enter download mode manually to recognize the serial port
GUI burning automatically corresponds to the file and address in the command
  • 2022.2.18 Ver2.2 firmware update
    • Optimize JPEG decoding
    • Optimize the power-on process
    • Modify some registers of st7789 to enhance the display effect
    • Modify the SDK and force compilation using -Ofast
    • Turn on some experimental compilation optimizations
  • 2022.2.26 Ver2.3 firmware update
    • Optimize the gamma register value of st7789
    • Deleted some debugging code
    • Optimized fps calculation
2022.3.4: Subsequent versions will be placed in the group file (not created yet)
There are many people asking questions in private messages. Here is a unified reply: I really don’t have time recently. I will wait until the college entrance examination is over. If you have any questions, you can figure it out on your own.
Demonstration video <--Give me three in a row~
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 04:33:56
  • IoT standards: Game over
  • Are there any photoelectric sensors with better temperature stability? How to perform temperature compensation?
  • Printed Circuits Handbook English 7th Edition Sharing
  • uboot burning problem
  • Share Shell Sort
  • BSL Programming Questions
