0BNOaY8ui
SH-003_Low power boost module
Redundant boost module
Q group 565264047 Welcome to play~
If you need cooperation, please contact the email root@an-ye.top
Configured in synchronous mode
Output 24V 3A
The dcdc is turned off by default when powering on, and needs to be turned on by pulling the EN pin high.
Use 8*6MM heat sink
MOS generates a lot of heat, so it is recommended to reduce the output current when using it.
The height of the solid capacitor is irreplaceable. Only this height is exactly parallel to the pin header.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 18:04:59
