OUkPcQS6f
CW32_QC_DRV main control board
CW32_QC_DRV main control board (base board)
Cooperate with open source projects: use with brushless DC motor driver board (power board) ,
The STM32_QC main control board (baseboard) replaces the original open source engineering core main control board with the STM32F103RCT6 chip.
Summary of design issues:
1. The baseboard is designed for the CW32 small blue board, so PA12 is connected to the buzzer, and STM32F1 has USB function, so the IO port of the STM32F103C8T6 core board is pulled up, so the buzzer will sound after powering on the ST. Disconnect the R10 resistor to disable the buzzer or change it yourself (there are still empty IOs). It is recommended to change PA11 as well.
2. The two electrolytic capacitors are designed to support the OLED screen, because there are differences in the positions of the copper pillar positioning holes for different 0.91'' OLEDs on the market. . . .
Resources Introduction:
1. Two buttons (three if you add the one on the core board)
2. A potentiometer (for speed regulation)
3.ESC electronic adjustment interface
4.Bluetooth interface/serial port
5.Buzzer
6.Two LEDs
7.1pcs 0.96OLED (pay attention to the pin order when buying)
8. Motor power board interface
The board is not designed to be within 10*10. I hope you don’t just go for it. This kind of board is not difficult. You can draw it within 10*10 according to your needs.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 05:54:35
