zpj6j
A separately powered HUB that costs 5 yuan (1-4)
First try for a novice, size: 3.8*3.6
If the cost is well controlled, it only costs less than five yuan.
There were two double-layer ports left before, so I just made use of them. In view of the battery problems of mobile devices (mobile phones and tablets), a type-c separate power supply was added (can be switched by a switch)
If you don’t need a separate power supply, you don’t need to solder the type-c 6p and switch (just use a piece of tin to connect them directly)
With the addition of an indicator light, you can choose other resistance values ​​to obtain appropriate brightness (no welding required)
Dynamic boom is uploaded in the attachment
Reference from the project of chen7654 boss
Original project address: https://oshwhub.com/chen7654/usb-hub#P5
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:20:23
  • NXP launches new generation TJA1048 dual high-speed CAN transceiver
  • The official source code was entered, but the LCD cannot be used
  • The problem with ETH_RESET
  • TMS320F28335 project development record 9_28335 interrupt system
  • OSD menu is shaking
  • COS6100G Oscilloscope User Manual
