fish001
QMK (supports VIA) 980 keyboard R2 developed based on ATMega32A
[Advantages] 1. The 6ROW+18COL keyboard combination is convenient for most people to use;
2. The QMK system can be customized to use your own imagination.
[Features] 1. Kaihua hot-swappable shaft seat design is used to facilitate the replacement of the shaft body (the pins of the shaft body are soldering pads. It is designed as a five-pin shaft and can be directly welded [for players without positioning boards]);
2. It uses 2812 lamp beads and cooperates with QMK to have rich RGB special effects;
3. Support VIA software.
[Attachment] The attachments include the BL of ATMega32A, the QMK source code of this keyboard (one does not support VIA, and the other supports VIA, please pay attention to distinguish), the sandwich stack shell file of this keyboard, BL and code programming tools, QMK develops the software required. (A link is provided for download, all relevant resources are there, see below) [The HEX source code file is attached below. See my other 980 configuration keyboard project for the shell, software, and BL class (Note: HEX files are not interchangeable with each other!!)]
PS: Link to the first version (main control can be replaced): https://oshwhub.com/dongshuo101/980-pei-lie-jian-pan-pcb
Link: https://pan.baidu.com/s/1Ryc4xah2Oa7YxfoPFs2Gqg
Extraction code: hi7r
                                     Thank you
to Bilibili "codeDuck". https://space.bilibili.com/1755131967 (QMK and VIA related technology sharing provided)
Thanks to Station B “HiryKun”. https://space.bilibili.com/50496994 (QMK related technology sharing provided)
Thank you to Station B for "Full Bridge Rigor". https://space.bilibili.com/2421963 (ATMega32A related technical documents and open source PCB provided)
Thanks to "Jun Daliang" at Station B. https://space.bilibili.com/617817373 (Provided technical sharing related to stacked shell drawing)
                                   Related website
QMK official website documentation: https://docs.qmk.fm/#/
Keyboard layout generation: http://www.keyboard-layout-editor.com
Keyboard Frimware Builder: https://kbfirmware.com/
Plate&Case Builder ( Stacked shell build website): http://builder.swillkb.com/
My personal space RomerShallD_bilibili_bilibili
https://space.bilibili.com/70894920
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 16:48:50
  • VMware (Hangzhou) Recruitment
  • Questions about microcontrollers
  • Unable to search for Bluetooth signal after adding characteristic value
  • Undocumented Pin usage in PYB
  • HTTP protocol implementation method based on hybrid TCP-UDP
  • VxWorks application layer communication program
