张三叔
LED8x16 dot matrix
physical object
To manually attach 8x16 0603 LEDs, it is recommended to use solder paste and a heating table for teppanyaki. Hot air guns and soldering irons are not suitable.
You can also use finished dot matrix modules:
test
After soldering, you can use Arduino to test. There is a library TM16xx LEDs and Buttons that drives TM16 series chips . Open the TM1640_matrix routine in the Arduino IDE and change the number of display columns to 16. Then you can test whether the LED is soldered properly.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:41:02
