桂花蒸
TD8655 step-down module
It has high-side and low-side drivers, allowing simultaneous configuration using two external power NMOSs.
The IC can operate in constant current (CC) and constant voltage (CV) modes.
The TD8655 operates as a DC regulator controller, providing constant current output from 1.2V to 28V and output currents up to 10A or more.
It features a constant current (CC) mode, allowing the output current to be set externally with ±7% accuracy.
Current mode control and external compensation enable feedback control with good linearity and load regulation, and flexible external design.
There are four independent current limit control pins for four separate loads.
Each of the current limits can be set across 100mV via a resistor (RCS).
Of course, the output peak current limit operates during normal operation.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 03:10:06
