太白金星
IP6505 dual-channel desktop charger
Based on Yingjixin IP6505, the maximum output is 24 W , and it integrates various fast charging output protocols : DCP/QC2.0/QC3.0 /MTK PE1.1/PE2.0/FCP/SCP/AFC/SFCP.
Typical output voltage and current are : 4V@3.6A , 5V@3.4A , 7V @ 3A , 9V@2.5A , 12V @ 2A .The buck conversion efficiency of IP6505 is as high as 97 % .
The module has been tested and the effect is good and the heat is low. It is recommended to use a 12-24V adapter. If a 12V output is required, it is recommended that the input be no less than 15V, and the maximum working voltage is recommended not to exceed 28V.
When connecting a fixed voltage adapter or battery, you do not need to solder the TVS and use a 5A slow-blow fuse.
TVS must be welded for 12V vehicles, model: SMF15A, and an 8A slow-blow fuse is used. It is not recommended for 24V vehicles (because no suitable TVS has been found).
Reverse connection of input power when using TVS will blow the fuse. Regardless of whether TVS is used or not, IP6505 and preamplifier will not be burned if the input power is reversely connected.
The copper pillars are M2X8mm. Caps on the way, to be replenished.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 19:42:34
