smallembedded
capacitor discharger
I have been using it for more than two years and it works great.
A must-have tool for switching power supply maintenance personnel. The shape of the tweezers is suitable for most capacitors. The built-in rectifier bridge input does not distinguish between positive and negative poles.
Working voltage: 60-600V
I forgot the working current, the 450v220uf capacitor takes about 3 seconds to discharge.
The 1mm diameter brass wire used for the probe is polished to a sharp point and then welded on. The sharp tip of the probe can easily pierce the residual flux and conformal paint on the solder joints.
Remember to cover the probe with heat shrink tubing for insulation.
The thickness of the board is 1mm. You can place the order directly after the files are assembled.
2022-5-15: Added the assembled version of the file (V1.0) to facilitate users to download.
2022-5-26: Added a tail ring-type fixing hole (V1.1) and a tail hook-type fixing hole (V1.2). The three options are the same but differ in appearance.
2022-6-28: The components of the transistor and rectifier bridge have been modified. The transistor uses 2SA1413, and the rectifier bridge has been replaced with a withstand voltage of 1Kv.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 16:20:47
  • Altera SoC Experience Tour + Received Board
  • Use buttons and digital tubes to make a dynamic display
  • Oil price increase, wages?
  • CB5654 Development Board Review 4
  • Selecting a Motor
  • Display the clock in the status bar using VC++ [Reprint]
