smallembedded
ATX power adapter board
Introduction
With 4 channels of PD fast charging detection, each channel is 30w (PD charging ic sw3526)
Main control ESP32-C3-01M
wifi automatic time synchronization (EspTouch distribution network) temperature and humidity monitoring (AHT20)
input current and voltage monitoring
5vsb port connected to 4 USBs, the board’s maximum output power is 5vsb 7a
5v port 8 USBs, the board’s maximum output power 5v19a
12v terminals 3, the board’s maximum output power is 12v48a
OTA upgrade (comes with web server)
Flash automatically saves wifi settings and last switch status
resource
PD charging board link: https://u.lceda.cn/join?type=project&key=dd1f40cf273c41fe97866108ab3ab3a9&inviter=58784f6417c749b89fc64e2fbf2bfa54
Firmware burning: target.bin in the attachment
Burning method
Do not solder the two 0R resistors R15 and R16 on the large board (download the program before soldering)
Connect the USB computer to the board, load target.bin through the flash_download_tool tool, the starting position is 0x0, and download the program for the esp32c3 master control
flash_download_tool download link: https://www.espressif.com.cn/zh-hans/support/download/other-tools
Instructions
Switch the ATX power supply on and off: short press the button on the voltage detection interface
Enter the distribution network mode: long press the button on the voltage detection interface for 3s---the screen displays "Smart Distribution Network"---use esptouch on the mobile phone to configure wifi, and the esptouch download link for Apple and Android ( https://www.espressif.com .cn/zh-hans/support/download/apps )
Enter wifi ota upgrade mode (network configuration must be completed first): click the button under the startup logo---after the IP address is displayed on the screen---open the interface on your mobile phone or computer to upload the firmware and you can upgrade
If you like it, give it a thumbs up
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 06:57:34
