aerobotics
Sample project_Panel printing design
Lichuang EDA professional version panel design sample file
New panel properties:
  • Name: the name of the panel project;
  • Material: Currently, there are two panel materials available: acrylic and PVC ;
  • Thickness: Set the panel thickness for printing production. The minimum thickness is 0.8mm and the maximum thickness is 3mm (subject to the final physical order);
  • Surface technology: There are currently only two options for panel surface technology: transparent and black translucent ;
  • Printing method: Select whether to print from the front or the back ;
  • Covering: The color selection of the covering panel, currently you can choose white or black ;
Please click to view more process parameters .
After filling in the relevant attribute information, the design drawing will be automatically opened.
Design drawing description
  • Anchor point: There is a square frame in the four corners (1, 2, 3, and 4 points) of the red silk border on the design drawing. That is the anchor point of the plate. It is used for positioning during production. It cannot be modified by default.
  • Plate frame: The red rectangular frame in the design is the size of the panel printing material of Lichuang Mall. The size is: 200x300mm.
Search Datasheet?
Forum More
Update:2025-08-03 07:31:43
