3228
Two-way power statistics plug-in board based on Atlink
Project Description:
  This is an intelligent two-way power statistics socket based on the Atlink CB3S module and developed using Atlink zero code. It controls the switch of the two-way socket through one-click network distribution and the mobile phone.
Software development:
Software development is based on the Atlink zero-code development platform, which can realize zero-code development and realize one-stop development of mobile phone and product software parts.
1. Enter the Atlink platform  -Register-Login-Product Development-Create Product
P8ohks0869xmPTwSyDOhi2h6zXmsqRB2BBQfEi5n.pngcfCF3HKazJiXyL7YBDmmA3YQfWKz911IfZyv96RH.png
After entering the product name and model, enter the five steps of development
1. Function definition
2. Select the panel
Third, hardware debugging, choose the module you need according to your needs. There are three modules to choose from, and configure the corresponding functions (the IO port set must be consistent with that on your hardware, otherwise it will not be controllable or abnormal in the future)
ja840VlGtZEQOUYZYDKuuPSXDzOocTQKny5sQEPh.pngABjNUaRngWmpJ72ojj2oB37qNvhzAFJj9SdErv8T.png
4. Product configuration:
5. Testing services. Since there is no product yet, it cannot be tested. We can only test it after the product is produced.
Sixth, go to Lichuang Mall to find the CB3S burning module, go directly to the module https://item.szlcsc.com/3143145.html, add it to the shopping cart, and go to the firmware distribution in the shopping cart (that is, tell Lichuang to burn it for you) that firmware)
Click Add Assignment, and the system will automatically display the firmware you made earlier. After you select the corresponding firmware, Lichuang staff will burn the firmware into the CB3S module and send it to you. You only need to solder it to your back after receiving the module. You can test it on the prepared board.
7. Use Lichuang free proofing to make circuit boards. It is recommended to use Lichuang EDA Professional Edition (if necessary later, you can bleach the shell, panel, etc. Lichuang benefits) to design https://lceda.cn/
Hardware. The rest is to wait for the board and parts to be assembled, soldered, and tested.
Project pictures:
3D renderings
PCBA:
Physical map:
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-06 02:07:45
