念慈菴
LM4766 power amplifier module
The LM4766 is a stereo audio amplifier capable of providing a single channel 40W output.
The LM4766's performance, utilizing its own Peak Instantaneous Temperature (Ke) (SPiKe) protection circuitry, places it in a class above discrete and hybrid amplifiers, providing an intrinsic, dynamically protected Safe Operating Area (SOA). Spike protection means these components are protected at the output against overvoltage, undervoltage, overload, including thermal runaway and transient temperature spikes.
Each amplifier within the LM4766 has an independent smooth transition fade in/out of mute, minimizing output pop-up. The IC's extremely low noise floor in the UV and its extremely low THD+N value of 0.06% power rating make the LM4766 best suited for high-end stereo TV or small form factor systems.
Type: AB class
Output type: 2 channel (stereo)
Maximum output power at different loads x number of channels: 40W x 2 @ 8 ohms
Voltage - Power supply: 20 V ~ 60 V, ±10 V ~ 30 V
Features: Eliminate pops, mute, thermal protection
Working temperature: -20°C ~ 85°C (TA)
Few external components
Quiet fade/silent mode
1.Typical applications:1.Typical applications:
2. Bridge application:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 05:01:21
  • Automatic watering system based on esp32s2-work submission
  • How to write technical requirements when drawing schematics?
  • Serial port error
  • Help! Help! Dual buck power input, one of the MOS tubes always burns out!
  • Please help me parse the ucos source code~~~
  • Help
