ghaytweyhtoo
Tone Capsule Preamp
The Santu Guitar Laboratory Tone Capsule Bass Preamp Bass Preamp Prototype
Darkglass Tone Capsule Bass Preamp System
has corrected the irregular layout design of the original version, optimized the power supply section, and greatly improved the noise floor problem of the original version.
The DuPont connector was replaced with a more stable XH2.54 connector, and the original inferior MLCC capacitors were completely replaced with Wima film capacitors, which brought about a great improvement in high-frequency performance!
Santu Guitar Lab's consistent all-plug-in design, its lifespan and durability far exceed that of chip circuit boards!
All types of components have gone through strict matching and screening (although the precision of the metal film is already very high, the larger numerical error can still be carefully selected).
The capacitors are all German Wima capacitors and the Japanese ELNA electrolytic capacitors. The
connectors are all gold-plated. The connecting wires are all made of copper
and the material is very high-quality. The solder joints are round, plump and very bright.
It adopts a detachable IC holder design, so you can replace your favorite op amp at will.
This product is open source CC-BY-NC-SA protocol
Attribution-Noncommercial-ShareAlike
Users may reprint, excerpt, remix, and create secondary works on this work, but they must not use it for commercial purposes and must be signed when using it. The content used in this work must also be authorized under this agreement.
All restricted behaviors under the CC license:
BY – You must give credit and provide a link to this License. At the same time, you need to declare whether the public creation has been modified. You can express the relevant information in an appropriate form, but it must not imply in any way that the authorizer has formally recognized you and your usage.
Non-Commercial (NC) – You may not use this creation for commercial purposes.
Share Alike (SA) – If you remix, transform, or create a new version of this work, you must distribute your work under the license that applies to the work.
No additional restrictions – You may not impose any legal or technical restrictions that would restrict others from doing what is already permitted by this License.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 18:41:11
