念慈菴
Snowflake lamp housing, it’s here! ! !
If you want to make a snowflake lantern, please go to the following link. Here is only the shell:
Many friends use 26mm ceramic filament but cannot find the corresponding 3D file. I also provide it in my Lichuang 3D model library. If you need it, you can follow me and get it directly from the 3D model library. If you want to render the actual picture, you can also You can pick it up from my accessories. I provide two types of sinking plate straight feet and patch curved feet. .
Shell description
  • Fully open source, all files can be downloaded in the attachment;
  • You can only apply the top layer or the upper and lower layers (I think as long as the upper layer is also very beautiful and thinner);
  • You can modify the pattern style yourself (Canada);
  • Customized acrylic cutting will be a little more expensive. I asked a lot of companies and it was 40 to 50 yuan. The last one said it was 30 (upper and lower shells). The boss said that if you go to his store later, it can be as cheap as 25 (upper and lower shells) with free shipping. (Starting price ) 20 free shipping (single case)
  • Upper and lower layers (nut M2, thickness between 1.35-1.6; screw M2*7or8);
  • Single upper layer (nut M2, thickness between 1.35-1.6; screw M2*5);
  • After putting the nut here in, use a soldering iron (250-300℃) to stick it on the nut and slowly iron it, and press it slowly so that it completely sinks into the shell and fits tightly with the shell to prevent loosening (be careful not to press too hard or for too long). Time high temperature is attached to the nut):
Before processing:
After processing:
Material description
shell
  • Whether cutting acrylic, 3D printing, light curing, etc., you only need to send the upper and lower shell files (STEP format) (or dwg format) in the attachment to the merchant. Each merchant has different needs, and I have provided them all.
  • The color does not have to be transparent, other colors are also acceptable (I haven’t tried it, but it should cost no extra money)
  • You can change the appearance, frosting, etc. by yourself (for example, change the surface to a fully sealed form)
shell link
24mm filament model (.wrl).zip
pcb model texture.zip
ks9 rendering package.zip
sldprt format file.zip
Assembly file.zip
Upper and lower shell files (dwg format).zip
Upper and lower shell files (STP-ap214 format).zip
Render pictures and videos.zip
BOM download
60229
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 16:51:25
