MartinFowler
[Verified] ESP32 photovoltaic MPPT step-down synchronous rectification [INA226]
2 INA226 solutions, both input and output voltage and current can be monitored
INA226 has soared from 5 yuan to more than 20 yuan due to the IC price increase. If you are interested, you can try the domestic alternative Silicone SQ52201FBC.
The detection voltage at the high voltage end should not exceed 36V, otherwise the ina226 may be damaged.
The low-voltage end detection version is not finished
Program update : GITEE https://gitee.com/muyan3000/esp32-mppt
Foreign open source handling  https://www.instructables.com/DIY-1kW-MPPT-Solar-Charge-Controller/
This project is modified from Gggggg's Lichuang version esp32 mppt - Jialichuang EDA open source hardware platform  https://oshwhub.com/gggggg/esp32-1kw-mppt_copy
The library name of INA226 is: INA226Lib
    INA226 Bi-directional Current/Power Monitor. Simple Example.
    Read more: http://www.jarzebski.pl/arduino/czujniki-i-sensory/cyfrowy-czujnik-pradu-mocy-ina226.html
    GIT: https: //github.com/jarzebski/Arduino-INA226
    Web: http://www.jarzebski.pl
    (c) 2014 by Korneliusz Jarzebski
Modification content:
Remove the usb-ttl part of the circuit and change it to a direct ttl interface
Remove a dcdc 3.3v circuit and use LDO to convert 5v to 3.3v
LCD power supply changed to 5V
Replace the following components with INA226
16  -bit /12-  bit precision  ADC  measurement  (ADS1115/ADS1015)
Automatic  ACS712-30A  current sensor calibration
LiquidCrystal_I2C lcd(0x27, 16, 2); //Set the liquid crystal address 0x27 and set the characters displayed in one line to 16 and 2 lines to display.
Initialize INA226 Slave1 0x40 A1 GND A0 GND
Initialize INA226 Slave2 0x41 A1 GND A0 VS
Program part:
Add OTA upgrade function
Modify Blynk to Blinker
Modify the voltage and current reading to INA226
Modify the problem that the battery voltage is judged to be in NOBAT state when it is lower than the system's minimum input voltage, resulting in the inability to charge.
20220707
Update the program corresponding to INA226 and the Blinker interface
Discuss with each other QQ:483012638
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 08:01:26
