张三叔
ETA2858 step-down power module
Thanks for the support of Jialichuang. The quality of PCB produced by Jialichuang is great!
The physical diagram and output voltage results are in the attachment.
The power chip uses ETA2858 designed by Yutai, and the package specification is EFN3X3-12. For detailed information, please view the chip manual in the attachment.
The model of the field effect transistor used is SED3080M, the type is N-channel, and the packaging specification is DFN3X3.
It is recommended that capacitors C1 and C2 be made of X7R material, with a voltage resistance of 50V and a package specification of 1206
Capacitors C3, C4, and C7 are made of X7R material, with a voltage resistance of 50V, and packaging specifications of 0603
Capacitors C5 and C6 are recommended to be made of X5R or above material, with a voltage resistance of 10V and a packaging specification of 0805
The resistor package specifications are all 0603, accuracy +1%, 1/10W
The inductance value of the inductor can be selected between 2.2uH-4.7uH, and the package specification is 1040
The diode model is 1N5819 and the package is SOD-323
All the above components are made of SMD components
Most electronic materials can be purchased in the Taobao store "Shenzhen Youxin Electronic Technology Co., Ltd.". If you are worried about buying fake products, you can search for "DC-DC step-down power supply module 6-36V converter" in "Uxin Electronics" 5V 5A /12V5A high current synchronous rectification and voltage stabilization" Click the text to jump to the link
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-08 17:52:59
