ohahaha
ESPNOW remote control ESP07S version based on ESP8266
A wireless remote control solution developed based on ESP8266 using the ESPNOW protocol is currently in the solution verification stage. The serial port of the ESP07S module can be directly connected to the serial screen. There is a serial screen interface on the board. When connected to the serial screen, it can be used as a remote control terminal. At the same time, the serial port screen interface can also be connected to the serial port of the controlled device, so that the board can be used as a controlled terminal. The ESP07S module is used to connect an external antenna, and the communication distance can be longer (about 100 meters, depending on the gain of the antenna). It is still under development and this project will continue to be improved. The top switch is the power switch, and there are four switches on the left and bottom. Different switch combinations can realize 1. Serial screen update program 2. ESP8266 download program 3. ESP8266 and serial screen communicate with each other (the serial screen can also be Control microcontroller, etc.)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 13:21:35
