张三叔
HNA-12MM54T Universal VFD display module
# EEI TECHNOLOGY FLUORITE Series HNA-12MM54T VFD Module
* **2x10 14-segment digital tube display, white phosphor (white VFD is extremely rare)**
* **Onboard Coretex-M0+ MCU, used to complete dynamic scanning logic, That is, the external microcontroller does not need to participate in refreshing the screen. You only need to send the ACSII code to this module, and the module will automatically process the data and display**
* **The data transmission method can be UART or SPI**
* **Low-cost wide-body PMOS array, Easier to solder**
* **The optimized power supply scheme enables the screen to reach maximum brightness and supports a wider voltage input (3-15V)**
* **The maximum power consumption is as low as 3W, fully heated filament and the highest Brightness display**
* **Optimized dynamic scanning logic, completely eliminating ghosting**
* **Program burning method: use STLINK UTILITY (STLINK needs to be adjusted to "Hot plug" mode, otherwise it will not be able to connect) . **
## Notice! Please read the following first!
* **The copyright of this project belongs to EEI TECHNOLOGY electronic studio. **
* ****This project is under the CC-BY-NC-SA license (i.e. Creative Commons-Attribution-Noncommercial-Share Alike) and commercial deduction (interception of parts of the original project or modifications based on the original project) is prohibited The new project that is born is called "deduction"). Even if it is not used for commercial purposes, it must be agreed by the original author and the project can be shared in the same way before it can be deduced (the original author's signature and source need to be marked), if the open source agreement is ignored And sell them, our studio will hold them responsible and carry out severe crackdowns! Please consciously abide by the open source agreement and jointly maintain the open source environment. ****
* **This project is for DIY and learning purposes only. It is prohibited to use this project for any commercial purpose of selling, disseminating, or copying. **
## About the display screen
* **This screen has been put on Taobao. If necessary, you can buy it in our store. The price is the latest quotation from the manufacturer. There is no purpose of screen speculation**
## Update log
* **The software has not been developed yet. At present Only test firmware is provided, the source code can be obtained by private messaging me**
## Data transfer protocol (temporary definition, may be changed later)
* **DCRAM: character generator, each DCRAM corresponds to a digital tube**
* **CGRAM: Custom data, for G1 and G12**
* **Setting: Settings, controlling screen on or off, and brightness adjustment**
![1640657897(1).jpg]
## Actual picture
![23b211d6fc225e9c2c7a88e8c88d83b.jpg]
![ cc0b7112aec9d47f5da831c86437e80.jpg]
![39004998fbd3dc62b724f14df032e82.jpg]
EPC-INBM32V1254UD_FirmWare.bin
BOM download
PCB_EPC-INBM32V1254UD_2022-09-24.pdf
PCB_EPC-INBM32V1254UD_2022-09-24.json
EPC-INBM32V1254UD_2022-09-24.pcbdoc
Gerber_EPC-INBM32V1254UD.zip
Schematic_HNA-12MM54T Universal VFD display module_2022-09-24.pdf
SCH_HNA-12MM54T Universal VFD display module_2022-09-24.json
EPC-INBM32V1254UD_2022-09-24.schdoc
61449
RT300-MKV 250W CNC step-up and step-down desktop adjustable power supply
Introduction: RT300-MKV-EXTREME synchronous hybrid power stage automatic range boost-buck digitally controlled adjustable power supply
EEI TECHNOLOGY 01P-HexaGon Series Project [RT300-MKV-EXTREME]
RT300-MKV-EXTREME自动范围数控升降压可调直流电源模块,具有恒压,恒流,自定义过压 ,过流 ,过功率  , 短路保护功能,并且带有数据存取功能,方便快速调出预设值。
为了减少MCU的性能浪费并提高可靠性,逻辑与显示部分用了实时操作系统(RTOS)。
采用同步整流混合功率级方案,最高效率可达95%,并且具有极低的电压纹波。
改进过的环路使直流增益趋近于无限大,以达到0.01%以下的负载调整率。
采用电压前馈控制,大幅提高动态响应速度。
不同于其他四开关升降压,本产品具有极快的动态响应速度,能够灵活的应对各种类型的负载。
功率部分采用固液混合型电容,在压缩体积的同时,保证极低的电压纹波。
高边电流取样,负载可以和输入电源共地而不影响电流的测量。
输入具有防反接功能,不必担心反接造成模块烧毁。
模块具有二极管仿真功能,有效避免电池充电时造成电流倒灌而导致模块烧毁。
采用高精度Σ-Δ ADC,使全范围测量误差小于0.05。
第三代自校准算法[AUTO CAL V3]具有极快的校准速度,可以在半秒内完成全范围的校准并保证稳定的输出。
版权说明
此项目版权为EEI TECHNOLOGY电子工作室所有。
此项目为CC-BY-NC-SA协议(即创作共用-署名-非商业性-相同方式共享)且禁止未授权的演绎(截取原工程部分或者在原工程基础上加以修改而诞生的新工程称之为“演绎”),即使被授权,也要以同样方式共享其工程才方可进行演绎(需要标注原作者署名以及来源),如无视开源协议并进行商业行为,本工作室将会追究其相关责任并进行严厉打击!请大家自觉遵守开源协议,共同维护开源环境。
此项目的显示部分(EPA-INBX32P4418PO)已经申请专利,请勿用以商业用途。
禁止未授权的二次开发(即基于原作品开发出新的作品,比如XXX电源模块,兼容RT300固件,基于RT300的xx功能扩展模块)
此项目仅供DIY以及学习之用,禁止将此项目用于一切商业行为(以牟利为目的贩卖,传播,复制)包括以上三点且不局限于以上三点。
为增加某些别有用心之人的制作成本以及时间精力(最大程度的确保我的产品不会被某电商平台的贩子量产并且倒卖),我对此项目的部分关键物料(部分电容,逻辑器件)进行了管控,敬请谅解!
因本人编程水平很差,以及为了避免不必要的版权纠纷问题(此处的“版权纠纷”是指如有人利用了我的源码进行商业行为,对方又不承认使用了我的源码,而嵌入式软件的取证是非常困难的,几乎无法取证,很难证明对方窃取了源码),故源码不公开(不要抱有侥幸心理来问我索要或者意图向我购买源码,我是不会给的),敬请谅解!
相关项目
显示板 EPA-INBX32P4418PO点击跳转
外壳相关(前后面板、电源板固定板)点击跳转
部分物料购买链接
CS106125 15uH功率电感点击跳转
CS166125 18uH功率电感点击跳转
HBW 80V 47uF固液混合电容点击跳转
HBW 63V 33uF固液混合电容点击跳转
OCV 35V 68uF固态电容点击跳转
散热模组点击跳转
液晶屏点击跳转
主要参数
输入电压范围 : 10-30V
最大输入电流应力 : 30A
最大熔断电流 : 25A
输出电压范围 : 0-50V
输出电流范围 :0-10A(根据输出动态调节恒流上限)
最大输出功率 : 250W
输出纹波 : 12V IN 24V OUT @ 3A  : 48mVpp(含噪声)
调节分辨率 : 0.01
设定-回读误差 : < 0.005
测量误差 : < 0.03</b>
全范围输出压降(0-10A) < 0.005
容量统计误差 : < 0.002WH / AH / 小时
数据更新速率  30Hz
ADC采样率 :1KSPS
采样间隔 :3ms
显示屏类型 :2.8" IPS FULL VIEW
动态性能(12Vin 24Vout 3A/us 0.5A -> 3A 50% 100Hz)
过冲/欠冲:< 25mV
恢复时间 :  < 1ms
环路带宽/穿越频率 :>= 25KHz
电流环切换速度 : < 200us
保护动作时间 :< 5ms
DS1Z_QuickPrint13.pngDS1Z_QuickPrint12.png输出纹波(12Vin 24V 3A Output)
image.png输出纹波(12Vin 50V 1.1A Output)
DS1Z_QuickPrint8.png静止状态下的输出纹波(12Vin 24V Output)
DS1Z_QuickPrint2.png输出端上电曲线 (50V)
DS1Z_QuickPrint7.png99%功率运行(12Vin)
image.png99%功率运行20分钟后的温度
image.png输入端电流(12Vin)
image.png产品正面图
image.png产品背面图
image.png功能框图
image.png固件会在完善之后上传,请耐心等待.
注意事项
此项目的PCB密度相对来说较高,请准备好热风枪,锡膏。
陶瓷电容切勿使用烙铁焊接,不然会有几率发生爆炸。
功率部分(Boost,Buck)的输出电容均为HBW固液混合型电容,请不要使用普通电解电容,可能会发生爆炸。
请勿抱有侥幸心理去替换某些物料,替换后有可能导致电源模块性能下降以及故障,且得不到任何技术支持。
给电池充电时,请勿反接电池,否则会导致模块烧毁。
BOM下载
PCB_EPA-INBM32P2245PR_V1.0_2022-09-24.pdf
PCB_EPA-INBM32P2245PR_V1.0_2022-09-24.json
EPA-INBM32P2245PR_V1.0_2022-09-24.pcbdoc
Gerber_EPA-INBM32P2245PR_V1.0.zip
Schematic_RT300-MKV 250W 数控升降压桌面可调电源_2022-09-24.pdf
SCH_RT300-MKV 250W 数控升降压桌面可调电源_2022-09-24.json
RT300-MKV 250W 数控升降压桌面可调电源_2022-09-24.zip
61450
RT300-MKV-PACK#4 电源前后面板以及电源板固定板
简介:RT300-MKV的电源外壳前后面板
适用于RT300-MKV电源模块以及显示板。
BOM下载
PCB_EPA-INBX32S4418PO_BK_2022-09-24.pdf
PCB_EPA-INBX32S4418PO_BK_2022-09-24.json
EPA-INBX32S4418PO_BK_2022-09-24.pcbdoc
Gerber_EPA-INBX32S4418PO_BK_2022-09-24.zip
PCB_EPA-INBX32S4418PO_MK_2022-09-24.pdf
PCB_EPA-INBX32S4418PO_MK_2022-09-24.json
EPA-INBX32S4418PO_MK_2022-09-24.pcbdoc
Gerber_EPA-INBX32S4418PO_MK_2022-09-24.zip
PCB_EPA-INBX32S4418PO_FK_2022-09-24.pdf
PCB_EPA-INBX32S4418PO_FK_2022-09-24.json
EPA-INBX32S4418PO_FK_2022-09-24.pcbdoc
Gerber_EPA-INBX32S4418PO_FK_2022-09-24.zip
PCB_PACK#4_2022-09-24.pdf
PCB_PACK#4_2022-09-24.json
PACK#4_2022-09-24.pcbdoc
Gerber_PACK#4_2022-09-24.zip
PCB_RT300-MKV-PACK2_2022-09-24.pdf
PCB_RT300-MKV-PACK2_2022-09-24.json
RT300-MKV-PACK2_2022-09-24.pcbdoc
Gerber_RT300-MKV-PACK2.zip
61451
STC8A8K64D4 LCM_DMA开发板
简介:为了测试STC8A8K64D4的LCM_DMA功能,单独画了块板子
STC8A8K64D4 seems to be STC's first MCU to support LCD_DMA function, so I drew a separate development board. The board size was originally drawn according to TK032RB422 (made by Tiky), but I didn’t understand the LG4573A driver IC, so I used the code written by their other 5-inch ILI9806G driver screen.
Has anyone studied the LG4573A IC? I would be very grateful if you could give me a C51 routine reference. For the time being, the code only runs through the basic LCM_DMA function, plus a font call.
See the code: https://github.com/XanaduNWH/8051/tree/main/STC8A8K64D4/Tiky_LCD_TEST_board The STC official website provides software library functions and application examples, but the naming of DMA still uses the pre-update BMM, and in some places and the new version of the header file It's still not correct, so I don't use the official function library.
The layout of the PCB board is very unprofessional, I hope someone can give me some guidance.
[ChangeLog]
2022/03/29
Corrected the buzzer circuit transistor wiring error
2022/03/25
Updated the GT30L32S4W packaging error;
exchange P54 and P55, P54 is changed to a button and a current limiting resistor is added, and P55 is changed to a pinout ;
Exchange P37 and P42, P37 (INT4) is changed to pinout, and P42 is changed to button; the download circuit made of CH340C used in
the power supply + download circuit
board is more expensive than CH340G, but there is less crystal oscillator on the circuit. If the automatic download fails using the TYPE-C interface for unified power supply
, you can increase C7 for better results.
CH340C uses USB direct power supply, and the whole version uses AMS1117 to step down to 3.3 power supply. The extension leads to a 5V power interface.
The LED circuit
board carries two IO-controlled LEDs, and P11 is the output port of the hardware PWM1_2.
Button circuits
P33 and P37 correspond to INT1 and INT3. INT0 gives the touch screen interrupt.
P51 is an ordinary IO button;
P54 is the NRST pin, although by default this pin is used as a standard IO;
the expansion interface
H1 is the hardware LCM_DMA channel corresponding to the LCD screen interface pin. (LCMIFCPS[1:0] = 00; LCMIFDPS[1:0] = 00;);
There are D16~D23 on the silk screen, but the pins are not wired because the MCU's LCM_DMA function only supports 16-bit width.
BL is directly connected to P1.0;
the screen touch interrupt is connected to P32 (INT0);
CN1 leads to the hardware SPI interface (P_SW1 = 0x00), sbit ex_cs = P1^2;
CN2 leads to the hardware I2C interface (P_SW2 = 0x00);
CN3 leads to UART4 (P_SW2 = 0x04);
CN4 leads to P6, which is the interface of PWM*_3;
CN5 is some IO that has nowhere to be placed;
CN6~8 is the 3V3 power interface;
the font chip
GT30L32S4W chip
provides 12, 16, 24, and 32 dot matrix size GB2312 characters, 4 sizes of GB extended characters, multiple ASCII character sets.
sbit zk_cs = P1^7;
Flash chip
W25Q64
sbit flash_cs = P1^6;
EEPROM chip
AT24C128N
Clock chip
DS3231
I2C interface (P_SW2 = 0x00 )
INT/SQW = P3^6;
Miscellaneous
A CR1220 battery holder, retaining the traditional VRTG4 line download interface.
VID_20220319_150335.mp4
BOM download
PCB_PCB_STC8A8K64D4 LCM_DMA Development Board_2022-09-24.pdf
PCB_PCB_STC8A8K64D4 LCM_DMA Development Board_2022-09-24.json
PCB_STC8A8K64D4 LCM_DMA Development Board_2022-09-24.pcbdoc
Gerber_PCB_STC8A8K64D4 LCM_DMA development board.zip
PCB_TK032RB422 Verification Board_Draft_2022-09-24.pdf
PCB_TK032RB422 verification board_draft_2022-09-24.json
TK032RB422 verification board_draft_2022-09-24.pcbdoc
Gerber_TK032RB422 verification board_draft.zip
PCB_TK032RB422 verification board_2022-09-24.pdf
PCB_TK032RB422 verification board_2022-09-24.json
TK032RB422 verification board_2022-09-24.pcbdoc
Gerber_TK032RB422 verification board.zip
Schematic_STC8A8K64D4 LCM_DMA Development Board_2022-09-24.pdf
SCH_STC8A8K64D4 LCM_DMA development board_2022-09-24.json
Verified version_2022-09-24.schdoc
61452
TM1650 based clock
Introduction: I originally wanted to use TM1650 to light up a digital tube, but ended up making it into a clock.
The package size is convenient for manual soldering.
There are three PCB prints, the mini one has a 0.56-inch digital tube, the 0.8 one has a 0.8-inch digital tube, and the other one is a draft, the size is weird and can be ignored.
The code and project introduction are all on Github
https://github.com/XanaduNWH/8051/tree/main/STC8G1K/CLOCK
Updated on 2022/03/18
The 12-pin digital tube with a colon point seems to have a decimal point that does not light up, no Do you know if all 12-pin ones are like this?
When placed together with the Mijia Bluetooth Thermohumidity Meter 2, the difference is about 2 degrees.
Update MenuIndex to PageIndex, and adjust the usage
to read the DS3231 internal temperature register and display it.
BOM download
PCB_PCB_TM1650_0.8_2022-09-24.pdf
PCB_PCB_TM1650_0.8_2022-09-24.json
PCB_TM1650_0.8_2022-09-24.pcbdoc
Gerber_PCB_TM1650_0.8.zip
PCB_PCB_TM1650_mini_2022-09-24.pdf
PCB_PCB_TM1650_mini_2022-09-24.json
PCB_TM1650_mini_2022-09-24.pcbdoc
Gerber_PCB_TM1650_mini.zip
PCB_PCB_TM1650_2022-09-24.pdf
PCB_PCB_TM1650_2022-09-24.json
PCB_TM1650_2022-09-24.pcbdoc
Gerber_PCB_TM1650.zip
Schematic_TM1650-based clock_2022-09-24.pdf
SCH_TM1650-based clock_2022-09-24.json
TM1650_MINI_2022-09-24.schdoc
61453
50w electromagnetic induction heating
Introduction: An electromagnetic induction heating using G40N60mos tube
Use a 2A-4A 12V power supply. It is recommended to use an adjustable power supply.
Ordinary power supplies will report overload and require a current limiting resistor.
As shown in the figure, the current limiting resistor
used here is
The limited resistance is as shown in the figure
a list of 1 ohm 50W aluminum resistor components;
G40N60*2
200-ohm*2
fr207*2
common mode inductor 5HM*1
0.22UF safety capacitor*4
10K*2
25V100UF*1
copper coil : 6 turns inner diameter 24mm, height 25mm
PCB_PCB1_2022-11-05.pdf
BOM_Board1_PCB1_2022-11-05.xlsx
Altium_50w electromagnetic induction heating_2022-11-05.zip
PDF_50w electromagnetic induction heating_2022-11-05.zip
BOM_Board1_Schematic1_2022-11-05.xlsx
61454
Genshin Impact Paramount Ruler 100*33mm
Introduction: Raw stone ruler 100*33mm
ruler front
BOM download
PCB_9cm Genshin Impact_2022-09-24.pdf
PCB_9cm Genshin Impact_2022-09-24.json
9cm Genshin Impact Pool_2022-09-24.pcbdoc
Gerber_9cm Genshin Impact.zip
61455
WCH-Link
Introduction: WCH-Link, produced based on Qinheng's official schematic diagram, can debug ARM and RISC-V architecture microcontrollers. It also has 1 serial port for convenient debugging output.
Referring to the official schematic diagram, there are almost no changes, except that the interface is changed to TYPE-C. It has been tested that it can debug ARM and RISC-V architecture microcontrollers, and it also has 1 serial port.
Detailed introduction can be viewed at Digital Home
https://www.mydigit.cn/thread-287203-1-1.html
PCB, project files, firmware and other information: Link: https://pan.baidu.com/s /1XP8IsFQYKRD82fJslzGJOg Extraction code: XDZZ
BOM download
61456
Xianyu 1.2VFD screen clock network time correction
Introduction: This clock is made with Xianyu 1.2 yuan VFD screen.
The clock is made with a Xianyu 1.2 yuan VFD screen and uses the 8266 module to obtain the network time. It does not use a clock chip and automatically obtains the network time every 300 seconds. The program is poorly written and is for reference only. The first version in the video uses three 595 driver segments and bits. Q communication group: 513391
66f6d104ead0434b700f7f98a03aed84.mp4
Specification: 14075-1A01.doc
8266vfd2595.zip
BOM download
PCB_PCB_PCB_2020-10-26_18-46-04_2022-01-12_2022-09-24.pdf
PCB_PCB_PCB_2020-10-26_18-46-04_2022-01-12_2022-09-24.json
PCB_PCB_2020-10-26_18-46-04_2022-01-12_2022-09-24.pcbdoc
Gerber_PCB_PCB_2020-10-26_18-46-04_2022-01-12.zip
Schematic_Xianyu 1.2VFD screen clock network time correction_2022-09-24.pdf
SCH_Xianyu 1.2VFD screen clock network time correction_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61457
2022 China Jiliang University Lichuang Cup Title A Signal Hybrid Transmission System
Introduction: Infrared optical communication is used to realize mixed transmission of digital and analog signals. While signal demodulation is achieved at the receiving end, signal integrity is retained as much as possible and noise interference is reduced.
The transmitting end avoids signal interference and adopts synchronous and independent transmission;
the receiving end mainly uses a multi-order filter circuit to demodulate the two-way signals. After demodulation, the signal is restored through amplification, filtering, and envelope detection circuits;
the relay point mainly To achieve reception and retransmission, in order to retain the integrity of the signal, the relay point undergoes two-stage amplification. In order to reduce the operating current of the relay point, filtering is performed at the receiving end;
while ensuring the integrity of digital signal transmission, a Bluetooth module is added Implemented mobile display of temperature.
(Please see the attachment for details)
Design summary report.docx
BOM download
PCB_PCB_Signal Processing 2_2022-09-24.pdf
PCB_PCB_Signal Processing 2_2022-09-24.json
PCB_Signal Processing 2_2022-09-24.pcbdoc
Gerber_PCB_Signal processing 2.zip
PCB_PCB_Signal Processing 1_2022-09-24.pdf
PCB_PCB_Signal Processing1_2022-09-24.json
PCB_Signal Processing 1_2022-09-24.pcbdoc
Gerber_PCB_Signal processing1.zip
PCB_PCB_Relay circuit_2022-09-24.pdf
PCB_PCB_Relay circuit_2022-09-24.json
PCB_Relay circuit_2022-09-24.pcbdoc
Gerber_PCB_Relay circuit_2022-09-24.zip
PCB_PCB_launch part_2022-09-24.pdf
PCB_PCB_launch part_2022-09-24.json
PCB_launch part_2022-09-24.pcbdoc
Gerber_PCB_launch part_2022-09-24.zip
Schematic_2022 China Jiliang University Lichuang Cup Question A Signal Hybrid Transmission System_2022-09-24.pdf
SCH_2022 China Jiliang University Lichuang Cup Title A Signal Hybrid Transmission System_2022-09-24.json
2022 China Jiliang University Li Chuang Cup Title A Signal Hybrid Transmission System_2022-09-24.zip
61458
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 18:30:51
