黄土马家
FM1922570CT6-00 module
The reference program needs to be used with this core board: The STM32G030F6P6 core board
module reserves the CS pull-down resistor R4. If the CS function is not needed, an IO can be saved.
The module reserves the backlight switch. When the BL pin is floating or at a high level, the backlight is turned on, and when the BL pin is at a low level, the backlight is turned off. If there is no need to turn off the backlight, you can solder R1 instead of Q1, R2 and R3.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 14:40:03
  • Does anyone know about NB-IOT?
  • MSP430 1602 LCD electronic clock
  • Image to PCB
  • Two examples of battery failure repairs for portable monitors
  • Commonly used introductory circuits for RF (1)
  • Low Voltage Hot Swap Controller for Adjustable Power Supplies
