toothache
【Training Camp】Tai Chi little bitch
First of all, pay tribute to the official sample -> Material list and reference purchase link: https://docs.qq.com/sheet/DWGxocU1aalRJS0Z2?tab=9e4zer Please use Hiburn.exe to burn the firmware program. See the attachment for the code and burning tools. See the application source code: https://gitee.com/genkipi/applications_genkipi_sample/tree/OpenHarmony-3.0-LTS/app/plotclock Complete environment code: https://gitee.com/genkipi/ohosdog Related information Baidu network disk: https: //pan.baidu.com/s/1OztwrWfjke83tJw3oP9gRQ?pwd=qu2sCopy the plotclock directory to the directory below in the complete environment ohosdog/applications/genkipi/app In fact, plotclock is a dog leg of the robot dog , you can learn the principles of forward and inverse solutions through the dog-leg morphology simulator https://gitee.com/tangyang/leg-kinematics The simulator is open source and supports the forward solution of dog-leg kinematics and the inverse solution of dog-leg kinematics. Movement range point simulation simulation map support Intrinsic parameters are dynamically adjusted to generate specified trajectories, font trajectories support digital fonts, alphabet fonts, Chinese character fonts, save modified parameters, and device synchronization simulation-------------------------- -------------------------------------------------- -----------------------------Dividing line------------------- -------------------------------------------------- ----------------------------------The PCA9685PW in the sample is expensive and out of stock. Try using an STC microcontroller instead. The PCA9685PW module is left to support the interface. After arriving, I found that the silk screen printing of the stc's pwm port was wrong, and it has been corrected on the latest pcb.8777.jpg
stc-isp-15xx-v6.90C.zip
IIC protocol driver source code.rar
Serial protocol driver source code.rar
VID_20220714_211351.mp4
BOM download
PCB_PCB_[Training Camp] Tai Chi Little Bastard_2022-09-23.pdf
PCB_PCB_[Training Camp] Tai Chi Little Bitch_2022-09-23.json
PCB_[Training Camp] Tai Chi Little Bastard_2022-09-23.pcbdoc
Gerber_PCB_【Training Camp】Tai Chi Little Bastard.zip
Schematic_[Training Camp] Tai Chi Little Bastard_2022-09-23.pdf
SCH_[Training Camp] Tai Chi Little Bastard_2022-09-23.json
Sheet_1_2022-09-23.schdoc
61768
【RA】Flowing water lamp
Introduction: A running water lamp based on Renesas RA microcontroller that can be controlled by infrared
The actual finished product of the running water lamp based on the Renesas RA microcontroller that can be controlled by infrared is as follows:
999.mp4
BOM download
PCB_PCB_【RA】Flowing water lamp_2022-09-23.pdf
PCB_PCB_【RA】Flowing water lamp_2022-09-23.json
PCB_【RA】Flowing water lamp_2022-09-23.pcbdoc
Gerber_PCB_[RA]Flowing water lamp.zip
Schematic_【RA】Flowing water lamp_2022-09-23.pdf
SCH_【RA】Flowing water lamp_2022-09-23.json
61769
ATmega32A with V-USB
Introduction: The verification core board of ATmega32a and V-USB is used to verify QMKfirmware. You need to burn the bootloader of USBasploader first, and then use qmktoolbox to burn the firmware file.
Atmega32a minimum system core board, using V-USB, is used for QMK firmware verification.
V-USB link https://www.obdev.at/products/vusb/usbasploader.html
usbasploader warehouse address https://github.com/baerwolf/USBaspLoader
QMKFirmware warehouse address https://github.com/qmk/qmk_firmware
QMK There are many firmwares suitable for ATmega32a in the official keyboard library, which can be tested directly by compiling them.
The attachment provides
              1. ATmega32a USBasploader Bootloader file (PD2 == D+; PD3 == D-; PD4 == BOOT).
              2. Keyboard firmware used for testing (MATRIX_ROW_PINS { A2, A3, A4, A5, A6, A7 } MATRIX_COL_PINS { D6, D5, D1, D0, C7, C6, C5, C4, C3, C2, D7, C0, C1 , A1, A0, B1, B2, B3, B4 }).
              3. Keyboard VIA file for testing.
USBasploader_32A.hex
wy60_usb_via.hex
wy60_usb_via.json
BOM download
PCB_REV 1.5_2022-09-23.pdf
PCB_REV 1.5_2022-09-23.json
REV 1.5_2022-09-23.pcbdoc
Gerber_REV 1.5.zip
PCB_REV 1.4_2022-09-23.pdf
PCB_REV 1.4_2022-09-23.json
REV 1.4_2022-09-23.pcbdoc
Gerber_REV 1.4.zip
Schematic_ATmega32A with V-USB_2022-09-23.pdf
SCH_ATmega32A with V-USB_2022-09-23.json
61770
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 06:57:46
