WQCyDIbOAy
【Training Camp】Little bitch, little bitch
Use MICRO-USB for power supply or xt60 interface for power supply. The maximum input voltage is 15v. The power conversion part uses C434505 LM1085S for power supply and a 1117-3.3 program. You can download plotclock here - Jialichuang EDA open source hardware platform (oshwhub.com)IMG_20220726_112902.jpg
BOM download
PCB_NEW_PCB_2022-09-22.pdf
PCB_NEW_PCB_2022-09-22.json
NEW_PCB_2022-09-22.pcbdoc
Gerber_NEW_PCB.zip
PCB_PCB_[Training Camp] Little Bitch, Little Bitch_2022-09-22.pdf
PCB_PCB_[Training Camp] Little bitch little bitch_2022-09-22.json
PCB_[Training Camp] Little bitch, little bitch_2022-09-22.pcbdoc
Gerber_PCB_【Training Camp】Little Bitch, Little Bitch.zip
Schematic_[Training Camp] Little Bitch, Little Bitch_2022-09-22.pdf
SCH_[Training Camp] Little bitch, little bitch_2022-09-22.json
Sheet_1_2022-09-22.schdoc
61957
6028rgb (3528 reverse sticker) six-way common anode module
Introduction: I want to make a bunch of 6028rgb keyboards and make some modules.
The resistor is a 0603 chip 330k resistor, which is connected to the RGB. The circuit diagram design is not perfect and I am too lazy to change it. If I have time, I plan to introduce the i2c protocol for independent control to achieve the effect of a dot matrix screen.
This solution supports 3528 reverse pasting monochrome
BOM download
PCB_6028RGB six-way module v2_2022-09-22.pdf
PCB_6028RGB six-way module v2_2022-09-22.json
6028RGB six-way module v2_2022-09-22.pcbdoc
Gerber_6028RGB six-way module v2.zip
61958
5.8g image transmission automatic frequency search/sweep
Introduction: Applicable to rx5808
Remove the resistor and the original design
CpIinyvvWPezN4e2rK2MAJEGZdbTDXbokno9EwA6.jpegl92ghiiqpsQLu49x5j9jSQlg0eJuUTDIFO6HWu9w.jpegof the wiring diagram rfn4zbEqTHmSVvGGoxpY8r2xK908lYEXhSPUytmR.png
comes from:
https://space.bilibili.com/508735236?spm_id_from=333.788.b_765f7570696e666f.1 The
design effect of drinking this bowl of poisonous chicken soup
is shown: https://www.bilibili.com /video/BV1dK411W7zX/
Video tutorial: https://www.bilibili.com/video/BV1mz411q7zt/
PCB_PCB_New Project1 copy_2022-09-22.pdf
PCB_PCB_New Project1 copy_2022-09-22.json
PCB_New Project1 copy_2022-09-22.pcbdoc
Gerber_PCB_New Project1 copy_2022-09-22.zip
Schematic_5.8g image transmission automatic frequency search_frequency sweep_2022-09-22.pdf
SCH_5.8g image transmission automatic frequency search and sweep_2022-09-22.json
Sheet_1 copy_2022-09-22.schdoc
61959
[Internet of Things] Hongmeng Smart WiFi Switch +4239667A
Introduction: Using Hongmeng Hi3861 chip to realize WiFi remote control of physical switches
About Hongmeng Internet’s smart WiFi switch
5594466817083474370641926206.mp4
BOM download
PCB_PCB_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A_2022-09-22.pdf
PCB_PCB_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A_2022-09-22.json
PCB_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A_2022-09-22.pcbdoc
Gerber_PCB_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A.zip
Schematic_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A_2022-09-22.pdf
SCH_[Internet of Things] Hongmeng Smart WiFi Switch +4239667A_2022-09-22.json
61960
esp8266 weather clock
Introduction: Network weather clock based on ESP8266
The 2022.06.06 update
adds new MP3 module voice content. The content sound is editable and you can replace the sound you like, but the beginning of the name needs to remain unchanged.
### Project introduction
uses esp8266 to drive three max7219, monochrome LED dot matrix, a 128x64 OLED, and a PCF8563M, which can obtain weather and automatically adjust the time.
### Project function introduction
* The main control uses esp8266* The display part uses max7219 to drive the LED dot matrix to display digital time, and a 1.3-inch OLED to display weather and human-computer interaction* The clock uses PCF8563M as the clock module, and adds Battery failure* Use three I/O ports to make four buttons for human-computer interaction* Use a photoresistor on the ADC port to adjust the dot matrix and screen brightness* Use a microwave module to detect whether there is human activity, which can be used with the photoresistor at night screen* and can plug in an MP3 playback module to realize weather voice broadcast* Independent OLED driver library, rich animations
Welcome to the open source communication QQ group: 216066270
----Effect video https://www.bilibili.com/ video/BV1ev4y1A7fi/
There is also a dot matrix version with the same hardware interface as this version
https://oshwhub.com/zhhhhf/esp8266-wang-lao-tian-qi-shi-zhong
<br /><br />
weather clock.zip
Voice broadcast sound.zip
BOM download
PCB_PCB_esp8266 Weather Clock-LED Version_2022-09-22.pdf
PCB_PCB_esp8266 Weather Clock-LED Version_2022-09-22.json
PCB_esp8266 Weather Clock-LED Version_2022-09-22.pcbdoc
Gerber_PCB_esp8266 weather clock-LED version.zip
Schematic_esp8266 Weather Clock_2022-09-22.pdf
SCH_esp8266 weather clock_2022-09-22.json
LED version_2022-09-22.schdoc
61961
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 09:33:58
