fish001
Throwing Star LAN Tap Butterfly
Throwing Star LAN Tap Butterfly, a wire-monitoring network packet capture tool,
is based on the principle of network cables. 568B 100M uses four network cables, and 1236 has two receivers and two transmitters. You only need to connect the wires to capture the data being transmitted.
The function of the jumper capacitor is to trick the computer into thinking that the network quality is not good and downgrade it to 100 Mbit/s.
At this point, you can use tools such as wireshark to capture packets.
62025
ov7670
Introduction: Image display using Arduino mini, ov7670 camera and tft1.8-inch LCD screen.
This ov7670 is the 7 yuan version without FIFO. The mini can acquire images at 10FPS and display them on the LCD screen. When displaying grayscale, it can be used for car tracking.
BOM download
PCB_PCB_ov7670_2022-09-22.pdf
PCB_PCB_ov7670_2022-09-22.json
PCB_ov7670_2022-09-22.pcbdoc
Gerber_PCB_ov7670.zip
Schematic_ov7670_2022-09-22.pdf
SCH_ov7670_2022-09-22.json
Sheet_1_2022-09-22.schdoc
62026
FC red and white machine game flash card Mapper0
Introduction: For proofing thickness, you need to choose 1.2mm FC red and white machine game burning card Mapper0. The board is being printed and has not been verified yet. You need to cooperate with kazzo to burn the game.
The FC red and white machine game burning card Mapper0
is being printed and has not yet been verified. It needs to cooperate with kazzo (click here to go to the kazzo project) to burn the game.
Proofing has been completed on 2022-01-22. One problem has been fixed. If you need proofing, please Use mapper0 to temporarily test the subsequent four-in-one and four-in-one experimental cards.
The proofing thickness needs to be 1.2mm.
MAPPER4 can also be used directly. Just search it in Kaiyuan Square.
BOM download
PCB_Mapper0 four-in-one experiment card_2022-09-22.pdf
PCB_Mapper0 four-in-one experimental card_2022-09-22.json
Mapper0 four-in-one experimental card_2022-09-22.pcbdoc
Gerber_Mapper0 four-in-one experimental card.zip
PCB_Mapper0 four-in-one_2022-09-22.pdf
PCB_Mapper0 four-in-one_2022-09-22.json
Mapper0 four-in-one_2022-09-22.pcbdoc
Gerber_Mapper0 four-in-one.zip
PCB_PCB copy copy copy_2022-09-22.pdf
PCB_PCB copy copy copy_2022-09-22.json
PCB copy copy copy_2022-09-22.pcbdoc
Gerber_PCB copy copy copy.zip
PCB_Mapper0_2022-09-22.pdf
PCB_Mapper0_2022-09-22.json
Mapper0_2022-09-22.pcbdoc
Gerber_Mapper0.zip
Schematic_FC red and white machine game flash card Mapper0_2022-09-22.pdf
SCH_FC Famicom game flash card Mapper0_2022-09-22.json
Schematic copy_2022-09-22.schdoc
62027
KAZZO FC red and white machine game card dump burner
Introduction: KAZZO fc game cassette dump tool
1. Full-pin components, the difficulty of welding is reduced (the interface is patch type-c);
2. TYPE-C interface, mainly because the data cable is hard to find now, you can change it yourself if you don’t like it Pin usb interface;
 KAZZO FC game card burner fc game cartridge dump tool
2. TYPE-C interface, mainly because the data cable is hard to find now, I don’t like it You can change the pins of the USB interface by yourself;
if you have any questions, please leave a message. I am also trying to make an FC cassette.
The verification has been completed on 2022-01-15 and the following problems were found;
KAZZO uses ver0.1.3, and the host computer is anago. It can dump and write normally, and requires the cooperation of the cassette;
the LED light is not used, the original circuit does not have an LED, this LED It was added with reference to Laomei, but there is no Laomei firmware. Those who understand the source code can add it by themselves;
the above required files can be found at https://zh.osdn.net/projects/unagi/wiki/kazzo_intro_en.
kazzo_INLpgmr_46pin schematic.pdf
kazzo_schematics.txt
BOM download
PCB_PCB_KAZZO_2022-09-22.pdf
PCB_PCB_KAZZO_2022-09-22.json
PCB_KAZZO_2022-09-22.pcbdoc
Gerber_PCB_KAZZO.zip
Schematic_KAZZO FC red and white machine game card dump burner_2022-09-22.pdf
SCH_KAZZO FC red and white machine game card dump burner_2022-09-22.json
62028
pico rocker chip
Introduction: Pico-based joystick chip
Original address of the pico-based joystick chip
: https://github.com/FeralAI/PicoFightingBoard
Source b: https://www.bilibili.com/video/BV1EF411M7Sf?spm_id_from=333.880.my_history.page.click
Proofing completed , all keys are available after testing. The V1.3 version was added
on 2022-06-22
. The difference from the previous version is that the pin position has been modified. This layout is more suitable for Chinese people's usage habits.
Added a reset button.
Pico.Fighting.Board.v1.1.Quick.Reference.pdf
GP2040-PicoFightingBoard_v0.4.3.uf2
BOM download
PCB_V1.3_2022-09-22.pdf
PCB_V1.3_2022-09-22.json
V1.3_2022-09-22.pcbdoc
Gerber_V1.3.zip
PCB_V1.0_2022-09-22.pdf
PCB_V1.0_2022-09-22.json
V1.0_2022-09-22.pcbdoc
Gerber_V1.0.zip
Schematic_pico rocker chip_2022-09-22.pdf
SCH_pico rocker chip_2022-09-22.json
pico rocker chip_2022-09-22.zip
62029
Solder paste pusher
Introduction: USB powered handheld syringe packaging solder paste pusher
It is powered by USB C and controls two motors to push the solder paste syringe, saving time and effort
. Demonstration video. Demonstration video
https://www.bilibili.com/video/BV1n44y1j7c6?share_source=copy_web
driver chip TC118S (the same pin position is acceptable)
3 types of PCB (circuit drive and bracket)
M3 copper pillar + M3 screw (bracket)
N20 reduction motor (Xiaobao 7 yuan 2 free shipping)
coupling (3mm-6mm)
screw M6 (acting as a lead screw)
nut M6 (acting as a lead screw ) Slide table)
-- excluding PCB, the cost is less than 30 yuan
BOM download
PCB_syringe thruster.PcbDoc_2022-09-22.pdf
PCB_syringe thruster.PcbDoc_2022-09-22.json
Syringe pusher.PcbDoc_2022-09-22.pcbdoc
Gerber_syringe thruster.PcbDoc_2022-09-22.zip
62030
Planck keyboard, 40% layout, three modes
Introduction: Planck three-mode PCB layout file, because it was drawn using other software, the 3D drawing of the light is sealed, and the actual layout will not be affected.
1. The only correction to the inverted shaft light is that the shaft seat may need to be polished before it can be installed.
2. Only steel plate satellite shafts can be used, and the space is limited.
The light control uses is31fl3733
8 bottom lights WS2812_5050
4 ws2812_2020 package status indicators (light 1: caps, numlock, light 2: Bluetooth 1: red, Bluetooth 2: blue, Bluetooth 3: green and 2.4G indicator: white, light 3 : Layer indicator, light 4: USB indicator) With driver, it can be modified at will.
Use U disk to drag and drop to upgrade the firmware.
QQ group: 1121219685
M2_PLANCE_2022_02_04-1941ea2.uf2
zoro_planck.zip
BOM for ZORO_P.xlsx
Pick Place for ZORO_P.csv
BOM download
62031
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:23:37
