念慈菴
CAT4201AGEVB: High Efficiency Buck Converter Evaluation Board
CAT4201AGEVB:  High Efficiency Step-Down Converter Evaluation Board
The CAT4201 is a high efficiency step-down converter optimized for driving high current LEDs. A patented switch control algorithm enables efficient and accurate LED current regulation. A single RSET resistor sets the full-scale LED string current up to 350mA at supply voltages up to 36V. The switching architecture of the CAT4201 enables extremely low internal power dissipation, allowing the device to be packaged in a tiny package without the need for a dedicated heat sink. The device is compatible with switching frequencies up to 1MHz, making it ideal for applications requiring small size and low value external inductors. Analog dimming and LED shutdown control are provided through a single input pin, CTRL. Other features include overload current protection and thermal shutdown. The device is available in a low profile 5-lead thin SOT23 package, making it ideal for space constrained applications.
The CAT4201 is a high efficiency step-down converter optimized to drive high current LEDs. A patented switching control algorithm allows highly efficient and accurate LED current regulation. A single RSET resistor sets the full scale LED string current up to 350mA from supplies as high as 36V. The switching architecture of the CAT4201 results in extremely low internal power dissipation allowing the device to be housed in a tiny package without the need for dedicated heat sinking. The device is compatible with switching frequencies of up to 1 MHz, making it ideal for applications requiring small footprint and low value external inductors. Analog dimming and LED shutdown control is provided via a single input pin, CTRL. Additional features include overload current protection and thermal shutdown. The device is available in the low profile 5-lead thin SOT23 package and is ideal for space constrained applications.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-13 14:59:55
