qoistoochee128
E7160SL-002GEVB: Ezairo ® 7160 SL Hybrid Demonstration Board - Reflow Version
E7160SL-002GEVB: Ezairo ® 7160 SL Hybrid Demonstrator Board - Reflowed version
The Ezairo 7160 SL Hybrid Demonstrator Board is designed to easily develop high-performance hearing aids based on the Ezairo 7160 SL hybrid. The board features many configuration options available via standard 0.1" header pins, and an on-board J-Link debugger based on the Atmel ATSAM3U2CA-AU microcontroller. Using a USB cable, the on-board debugger is used to interface the RSL10 radio within the Ezairo 7160 SL hybrid with a PC for debugging, data collection, or monitoring purposes.This version of the board is optimized for RF testing and characterization. The Ezairo 7160 SL hybrid is directly reflowed on the board, which minimizes the impedance between the onboard matching network and the Ezairo 7160 SL. Note: The E7160SL-001GEVB doesn't contain an Ezairo 7160 SL module, which are sampled separately. The E7160SL-002GEVB contains one hybrid module soldered onto the board.
Features and Applications
On-board J-Link adaptor for debugging through a USB connection to the PC
Alternate on-board SWJ-DP (serial-wire and/or JTAG) interface for debugging the Arm ® Cortex-M3 processor
Access to all Ezairo 7160 SL peripherals via standard 0.1" headers
Onboard 4-bit level translator to translate the DIOs and debug interface at low voltage to a 3.3 V JTAG debugger
4 Push Button Switches
On board 3.3 V Regulator
3 LEDs
Test points and GND hooks for easy probing
Battery Holder
Current measuring header
Antenna matching and filtering network
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-30 09:32:52
