aerobotics
LM2595ADPBCKGEVB: Step-Down Switching Regulator Evaluation Board
The LM2595 regulator circuit is ideal for easy and quick design of step-down switching regulators (buck converters). It is capable of driving 1 A loads with excellent line and load regulation. The device is available in an adjustable output version and is internally compensated to minimize external component count, simplifying power supply design. Demoboard size: 55mm x 35mm Features and Applications Features Adjustable output voltage range 1.23 V 37 V Guaranteed 1 A output load current Wide input voltage range up to 40 V 150 kHz fixed frequency internal oscillator TTL Shutdown function Low power standby mode, 50 _A typical Thermal shutdown and current limit protection Internal loop compensation Moisture Sensitivity Level (MSL) equal to lead-free package Simple Applications High Efficiency Buck Regulator High Efficiency Pre-regulator for Linear Regulator On-Card Switching Regulator Positive and Negative Converter (Buck-Boost) Negative Boost Converter Battery Charger Power Supply
The LM2595 regulator is circuit ideally suited for easy and convenient design of a step-down switching regulator (buck converter). It is capable of driving a 1 A load with excellent line and load regulation. This device is available in adjustable output version and it is internally compensated to minimize the number of external components to simplify the power supply design. Demoboard size: 55mm x 35mm
Adjustable Output Voltage Range 1.23 V 37 V
Guaranteed 1 A Output Load Current
Wide Input Voltage Range up to 40 V
150 kHz Fixed Frequency Internal Oscillator
TTL Shutdown Capability
Low Power Standby Mode, typ 50 _A
Thermal Shutdown and Current Limit Protection
Internal Loop Compensation
Moisture Sensitivity Level (MSL) Equals
Pb-Free Packages are Available
Simple High-E fficiency Step-Down (Buck) Regulator
Efficient Pre-Regulator for Linear Regulators
On-Card Switching Regulators
Positive to Negative Converter (Buck-Boost)
Negative Step-Up Converters
Power Supply for Battery Chargers
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 20:57:02
