super_star
NCP1250B40WGEVB: 40 W Laptop Adapter Demonstration Evaluation Board
NCP1250B40WGEVB:  40 W Notebook Adapter Demonstration Evaluation Board
The NCP1250 is a highly integrated PWM controller capable of delivering a rugged and high performance offline power supply in a tiny TSOP-6 package. With a supply range up to 28 V, the controller hosts a jittered 65 kHz or 100 kHz switching circuitry operated in peak current mode control. When the power on the secondary side starts to decrease, the controller automatically folds back its switching frequency down to a minimum level of 26 kHz. As the power further goes down, the part enters skip cycle while limiting the peak current.Over Power Protection (OPP) is a difficult exercise especially when no-load standby requirements drive the converter specifications. The ON proprietary integrated OPP lets you harness the maximum delivered power without affecting your standby performance simply via two external resistors. An Over Voltage Protection input is also combined on the same pin and protects the whole circuitry in case of optocoupler failure or adverse open loop operation.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-14 11:33:14
  • An error occurred while loading wince
  • Things to note when purchasing LED lamps
  • 0 basic graduation project, please give me some advice
  • Repeated restart problem when VxWorks boots the system?
  • Zigbee serial port
  • RAM and ROM
