Lemontree
NCP380HSN05AGEVB: High-Side Distribution Switch Evaluation Board
NCP380HSN05AGEVB:  High-Side Power Distribution Switch Evaluation Board
The NCP380 is a high-side power distribution switch designed for applications where heavy capacitive loads and short-circuits are likely to be encountered, incorporating a 70 mΩ (DFN package), P channel MOSFET in a single package.The device limits the output current to a desired level by switching into a regulation current-mode when the output load exceeds the current-limit threshold or a short is present. The current limit threshold is either user adjustable between 100mA and 2.1A via an external resistor or internally fixed.The power switch rise and fall times are controlled to minimize current ringing during switching.An internal reverse-voltage detection comparator disables the power-switch if the output voltage is higher than the input voltage to protect devices on the input side of the switch. The /FLAG logic output asserts low during over current, reverse-voltage or over temperature conditions. The switch is controlled by a logic enable input active high or low.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 03:54:07
  • Has anyone used the MARVELL8686 WIFI module?
  • Newcomer Registration
  • PI experts give some advice on LED lamp driver design
  • Questions about the use of TL431
  • Tft LCD screen does not display,
  • RC charging calculation method
