newrudeman
NCP5269GEVB: Synchronous Buck Controller with 2-Bit VID for System Agent Evaluation Board
NCP5269GEVB: Synchronous Buck Controller with 2-bit VID for System Agent Evaluation Board
NCP5269 is a synchronous buck controller that is optimized for converting the battery voltage or adaptor voltage into power supply rails required in notebook and desktop system. NCP5269 is designed for applications requiring dynamically selected slew−rate controlled output voltages. The soft−start is programmed by a single capacitor. Voltage identification logic−inputs select four resistor programmed
set−point reference voltages that directly set the output voltage of the converter between 0.65 V to 1.5 V. NCP5269 supports high efficiency, fast transient response and provides power good signal. ON Semiconductor proprietary adaptive−ripple control enables seamless transition from CCM to DCM, where converter runs at reduced switching frequency with much higher efficiency. The part operates with input voltage ranging from 3.3 V to 28 V. NCP5269 is available in a 20−pin 3 mm x 3 mm QFN package.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 11:52:50
