3228
NCP81296GEVB: NCP81296GEVB hot-swappable smart fuse evaluation board
NCP81296GEVB: NCP81296GEVB Hot Swap Smart Fuse Evaluation Board
Features and Applications
12-V (typ) operation
Enable Input
~55 A current limit (default), programmable current limit using onboard resistor R19
Hiccup Mode for Following Protection Features
o Current-limit after Delay
o Fast Short-circuit Protection
o Over-Temperature Shutdown
o Excessive Soft-start Duration
Programmable output voltage slew rate control C4
An additional opportunity to insert a current loop to control the input or output current
through the device (M9, M10 and M11, M12), respectively. By default are shorted.
TVS diode for input transient protection
On-board Schottky diode at output prevents negative spike during overcurrent faults
LED status indications
Hot-Swap, Hot-Plug
Server standby rails
Routers and switches
Industrial PC
Search Datasheet?
Forum More
Update:2025-08-11 12:45:48
