smallembedded
NCV7692DRLV1GEVB: NCV7692DRLV1GEVB High Current Daylight Driving Light Evaluation Board
NCV7692DRLV1GEVB: NCV7692DRLV1GEVB High-current Daylight Running Light Evaluation Board
The evaluation board demonstrates high current daylight running light (DRL) solution. The board regulates constant current of 0.54 A through two on board white high power LEDs in the wide range of the supply voltage. The current is reduced for the board temperature above 85C. The cooling is provided through passive heat sink mounted on the bottom side of the board. In case of LEDs short or opening, the current source is disabled and the fault may be detected by the ECU diagnostics.
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-30 17:02:06
