sigma
NCV7707GEVB: Door Module Driver Evaluation Board
The NCV7707GEVB evaluation board provides a convenient way to evaluate the NCV7707, a powerful driver for automotive body control systems. The device is designed to control multiple loads at the front of the vehicle. The monolithic IC is capable of controlling mirror functions such as mirror positioning, heating and folding, including electrochromic mirror functions. In addition to two half-bridge outputs for controlling lock and security lock motors, the device has four high-side outputs to drive LEDs or incandescent bulbs (up to 10W). For maximum flexibility, all lighting outputs can be PWM controlled via PWM inputs (external signal source) or an internal programmable PWM generator unit. The NCV7707 is controlled via a 24-bit SPI interface with intra-frame response. The NCV7707GEVB Evaluation Board provides a convenient method to evaluate the NCV7707, which is a powerful driver for automotive body control systems. The device is designed to control several loads in the front foor of a vehicle. The monolithic IC is able to control mirror functions like mirror positioning, heating and folding including the electro-chromic mirror feature. Besides two half-bridge outputs to control lock and safe-lock motors, the device features four high-side outputs to drive LEDs or incandescent bulbs (up to 10W). To allow maximum flexibility, all lighting outputs can be PWM controlled thru PWM inputs (external signal source) or by an internal programmable PWM generator unit. The NCV7707 is controlled thru a 24 bit SPI interface with in-frame response.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 07:42:14
