兰博
NCV8537MN500GEVB: 5.0 V LDO Regulator Evaluation Board
The demoboard supports the LDO regulator NCV8537 in DFN10 package with fix output voltage 5.0 V. The ENABLE function allows turn the device to low consumption mode with quiescent current below 1 µA. The Power Good pin allows output voltage monitoring. The additional CNR capacitor reduces the output noise.Size: 45mm x 30mm x 18mm
Features and Applications
High Accuracy Over Line and Load (±0.9% at 25°C)
Operating Temperature Range: -40°C to 125°C.)
Stable Output with Low Value Capacitors of any type and with no Minimum Load Current Requirement Incorporates Current Limiting and Reverse Bias Protection
Low Noise (33 Vrms w/10 nF Cnr and 52 Vrms w/out Cnr)
Low Shutdown Current (
Thermal Shutdown Protection
Current Limitation
Requires Only 1.0 µF Output Capacitance for Stability
Power Good Output to Indicate the Regulator is Within Specified Limits
Networking Systems, DSL/Cable Modems
Audio Systems for Automotive Applications
Navigation Systems
Cable Set-Top Box
Satellite Receivers
Displays and Monitors
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 04:50:28
