3228
SECO-NCP51530HB-GEVB: Application daughter card for the NCP51530 half-bridge gate driver
SECO-NCP51530HB-GEVB: Application daughter-card for NCP51530 half-bridge gate driver
The SECO-NCP51530HB-GEVB helps users simplify and accelerate the design phase of switching components in high-voltage (half-bridge) gate driver applications, using the high-performance 700V-3.5/3.0 A high-side and low-side MOSFET driver NCP51530, two different MOSFET packages (DFN5 and WDFN8) and a large number of test points for optimal performance. Users can adjust gate resistors, bootstrap circuits and dead time and monitor switching behavior. The daughter card is compatible with the SECO-GDBB-EVB gate driver baseboard, allowing up to 3 half-bridge daughter cards to be tested simultaneously and performance compared.
The SECO-NCP51530HB-GEVB helps users simplifying and accelerating the design phase of switching parts in high voltage (half bridge) gate driver applications with the high performance, 700V-3.5/3.0 A high and low side MOSFET DRIVER NCP51530, two different MOSFET packages (DFN5 and WDFN8) and numerous test points, in order to obtain optimal performance. User is able to adjust gate resistances, bootstrap circuit and dead time and to monitor switching behavior. This daughter card is compatible with the SECO-GDBB-EVB gate drivers? baseboard, which allows testing up to 3 half bridge daughter cards simultaneously and comparing performances.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-17 10:23:31
