石榴姐
STR-NCV8170-NCP170-EVK: Strata Enabled NCV8170/NCP170 - 150mA LDO with fixed output voltage from 1.2V to 3.6V
STR-NCV8170-NCP170-EVK: Strata Enabled NCV8170/NCP170 - 150mA LDO with Fixed Output Voltage From 1.2V to 3.6V
The STR-NCV8170-NCP170-EVK provides an evaluation kit for the NCV8170 and NCP170 family of 150 mA CMOS ultra-low quiescent current XDFN4 packaged LDOs with fixed output voltages from 1.2 V to 3.6 V. With a typical ultra-low quiescent current of 500 nA, the NCV8170 and NCP170 are optimized for battery-powered applications. The NCV8170 is suitable for automotive and industrial applications. This evaluation kit can be used in conjunction with the Strata environment GUI, which enables/disables the LDOs as well as monitors other telemetry data on the platform including input/output voltages, power consumption, and temperature. For more details, visit the Strata web page at www.onsemi.com/strata! Click to Download Strata Features and Applications Features There are 4 different LDO series to choose from, each with a range of voltage options Vin ranges from 1.1V to 5.5V Maximum load ranges from 150mA to 300mA Vout ranges from 0.6V to 5.3V Automotive options available Applications DC-DC Power Supplies Battery Powered Equipment Analog and RF Automotive
The STR-NCV8170-NCP170-EVK provides an evaluation kit for the NCV8170 and NCP170 series of 150 mA CMOS ultra-low quiescent current XDFN4 package LDOs with a fixed output voltage range from 1.2 V to 3.6 V. With a typical ultra-low quiescent current of 500 nA, the NCV8170 and NCP170 are optimized for battery powered applications. The NCV8170 is rated for automotive and industrial applications. This evaluation kit can be used in tandem with the Strata environment GUI which can enable/disable the LDO as well as monitor other telemetry on the platform, including input/output voltage, power dissipated, and temperature. See the Strata webpage at www.onsemi.com/strata for more details! Click to Download Strata
Vin range from 1.1V to 5.5V
Max load range from 150mA to 300mA
Vout range from 0.6 V to 5.3V
DC-DC Power
Battery Powered Devices
Analog and RF
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 14:33:51
