smallembedded
Touch stepless dimmable snowflake lamp (smash-resistant and drop-resistant version)
Original version: mondraker
Original link: https://oshwhub.com/mondraker/snow_light
Modified version: resistant to smashing and falling, the cost has reached a new low.
Reasons for the revision: I saw the project of the boss Mondraker and also the modified version of zh2345. Indeed, the ceramic filament is really expensive (not to refute the project of the boss), which costs about 50 cents each (according to the previous opinions of zh2345, no The protective case is really easy to break the light). I have been coming to Jialichuang for a while and I can get nothing for free. Because in Hainan, the freight from Jiangsu warehouse is really expensive. It costs 8 yuan for me from Guangdong and 8 yuan from Jiangsu. 18 yuan, these ten yuan can get another 300 lamp beads. The 6021WS desk lamp stepless dimming chip used by zh2345 is still in stock in Jiangsu warehouse all year round! It’s neither progress nor retreat, so I had to modify it on the original version of the boss Mondraker. (I am a freshman in high school and I really don’t have much money, so the whole plan is to move towards the lowest cost possible)
Advantages: Compared with the big guy’s one, this one uses ordinary LED lights that are “already available at home”. You can use different quantities. Match warm white light beads to get the color temperature you want; you can also use colored lamp beads to make a unique snowflake lamp. It also has an extremely low cost (you can even remove it from a broken LED light at home and use it. As for the lifespan, of course it won’t be very long). It is resistant to smashing and falling, and the light will not break even if you sit on your butt. (It is recommended that the thickness of the board is 1.6. If it is too thin, it will bend and break easily.)
Disadvantages: It cannot transmit light and requires the use of a heating table (Teppanyaki) or a heat gun. It is not suitable for beginners and requires a certain degree of welding experience. Favors experienced players with complete equipment.
Here are some suggestions for friends who want to make snowflake lanterns:
1. If you are a good-looking player, then I recommend the original version of Monndraker https://oshwhub.com/mondraker/snow_light
2. If you are a novice player and only have a soldering iron. , I recommend you to do the revision of zh2345, https://oshwhub.com/zh2345/chu-mo-wu-ji-diao-guang-xue-hua-
3. If you are an old player and short of money, I will definitely give this a try. is the best choice (of course, you must have a heating table or a heat gun)
and my name is B station: It turns out that Xiaoqizi
may shoot and make videos later.
If there are any problems with the production, you can add q. Group: 723466456 (electronics enthusiasts can also join, not recommended for idlers, people who are not online all year round, and people with social fears, group quota is limited)
If you really don’t want to do it, it may be listed in the seafood market later, just Pick up at your door, no postage, you can check the comment section.
It is stated that it is not for commercial use and will not be sold in bulk.
         Commercial use is prohibited! ! !
Now that I’m here, I’ll post the picture:
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:33:40
