HnGuNoVr
stc15w201s-board-8bit
stc15w201s smallest system board
* with usb to ttl, using ch340n, sop8 package, convenient and easy to use, the usb interface uses micro-usb interface
* two leds, which represent whether there is data transmission in the rx and tx channels when downloading the program, usually Can be used as ordinary IO and LED
* Two micro switches and a reset switch, the two micro switches are silent micro switches
* All pins are led out using pin headers, which is convenient for using DuPont wires to connect external devices.
I have some stc15w201s chips on hand. , so I designed this simple minimal system board, which is perfect for DIYing some small things.
Please refer to the program template: [github](https://github.com/shuai132/STC15_LIB)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:49:05
