n8f6Oib7
Coke Power Bank 3.0 (two-way 20W)
The source of the project is from B station up owner @MJhan, who is a hand rub monster. This design aims to add a fast charging solution to the project.
This project is applied to a mobile power supply with a Coke appearance to achieve PD/QC fast charging and discharging and lithium battery management. Function.
    -git open source address: https://github.com/SuperPrintf/OpenCansPower
    -b station video address: https://www.bilibili.com/video/BV1NV4y1J7MQ
#WARNING⚠️⚠️⚠️
    -The chip must use the standard version, IP5358_BZ
    -Online Many sellers sell incorrect versions of chips, so be sure to carefully consider the store where you buy it
    - if you buy the wrong chip, it will have different functions, there may be logic failures, and it may even not work properly
    - before you find a formal purchasing channel It is recommended not to copy this project
    - the peak current of the battery terminal is above 5A, be sure to ensure the current carrying capacity of the battery
    - the connecting cable used must ensure the carrying capacity, otherwise the motherboard will report an error or even burn the board at high temperature
#Supplementary instructions
    - Please see B for production details Website video content
    - the outer shell is real cola skin
    - the internal container is 3D printed (it is recommended to use 3D Monkey), the 3D model is in the git warehouse
    - I am not the original author of this idea, this project is a motherboard with fast charging function designed after communicating with the original author
    -The author's original power bank is relatively simple to make, but it does not support fast charging! There is also the original content in the git repository
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 09:21:55
