supremeOne
STM32F722 flight control
Main control: stm32F722RET6
Gyroscope: Choose one of mpu6000 or BMI270 or ICM42688P
OSD: AT7456E External interface: You can choose 6 motor interfaces, 6 serial ports or 8 motor interfaces, 5 serial ports
                  IIC; ADC: RSSI, current detection; camera control interface
                  supports color LED, BB ring
                  10P ESC interface
                  6P high-definition image transmission interface
Barometer: BMP280
Black box: W25N01G 128Mb large black box
BEC: 5V2A
       : 10V2A
flight control size 37*37MM, 30.5*30.5MM hole position, hole diameter 4MM, can be put on The shock-absorbing rubber ring is used to install
the flight control using a 10P ESC interface, which is compatible with TMOTOR's 10P interface flight control. Other ESCs may need to modify the line sequence
to support the 6P high-definition image transmission interface. However, if used, pay attention to the line sequence
Notes:
1 .Since Jialichuang has modified the 6-layer board prototyping rules, free prototyping of this flight control board is no longer available.
2. It has been installed and tested for flight, and there are no problems, but only the betaflight firmware has been tested. INAV firmware is pending development and testing.
3. The betaflight programming firmware uses STM32F7X2 general firmware and is configured using a dedicated config file. Supports 6 serial ports and 6 motor modes or 5 serial ports and 8 motor modes, which can be configured as needed.
4. The flight control schematic diagram is self-designed and is not compatible with any existing flight control firmware on the market. It needs to be flashed using the configuration file provided here.
5. Friends who often follow Jialichuang may have seen this flight controller... Well, it's a bit embarrassing to say, maybe because there are few front components, they seem to mistake it for a fake 6-layer board. Yes, the customer service staff has apologized. Please also understand that this is purely a misunderstanding. This is a flight control that has been carefully designed and has been installed and flown. It is not a shoddy thing.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 08:31:54
