h3Vqbp
Force feedback knob based on ESP32 S3, can be used as a Bluetooth controller
This work is inspired by smartknob (both hardware and software are incompatible) and achieves a thinner and smaller structural design.
A 24mm diameter brushless motor is used internally, with a single-stage gear transmission, and a 40mm large-diameter ball bearing is used to connect the rotating outer ring and the body to improve the feel.
The battery-less version is only 28mm tall, while the battery-powered version is 34mm tall, and both have an outer diameter of 55mm.
The circuit board is designed using the EDA pro version.
The software is developed based on Arduino and edited using VS Code.
Assembly: https://www.bilibili.com/video/BV1xe411j7kV/?spm_id_from=333.999.0.0
Demo: https://www.bilibili.com/video/BV1po4y1t7Jr/#reply163427131360
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-07 08:00:46
  • Low voltage input DC/AC converter module
  • How to write a microcontroller program
  • Positioning method based on Zigbee underground wireless sensor network
  • MSP430 MCU Example 5-16 Pattern Light Control
  • How to write quadrature modulation in Verilog?
  • Complementary filtering algorithm (two-wheeled balancing car)
